Alright, I'm using a stealthmode oil kit that was on a T25 Mitsu turbo. It's going on a big 16g but it doesn't line up. I drilled the mounting holes a little larger, and it seems to be okay...but will I be fine?
16g Oil Drain
I figured out that problem. When going from a 2g to 1g DSM turbo (T25 to 14b/16g) you can reuse the stock oil drain just drilling the holes larger, which is what I did. So good.
Only problem I'm having now is adapating this T25 oil feed line to this 16g. I have to get a fitting that will thread into the 16g AND the T25 feed line. BOO!wat
