Below are the things i currently have for my engine build/turbo build, im going for 350whp daily driven, and turn it up couple psi for the track, every now and than, maybe 400-450whp max, Im not gonna re-sleeve the f22 block, however i am thinkin of either block posting or block filling, still need to do more research on that, I understand that tunning and the right turbo is very very crutial to the setup, however i am only asking for suggestions on which parts I need to handle the power, ie high volume oil pump, etc. Thanks for any help!
Things I have:
Fully built head;
-Some Port and Polish
-3 Angle Valve Job
-Flat Mill Decks
-Crower Acura RSX Dual Valve Springs (custom fitted)
-Crower Acura RSX Titanium Retainers (custom fitted)
-Ferrea 30mm Exhaust valve, 5.46mm stem, 123.55mm OAL
-Ferrea 33mm Intake valve, 5.48mm stem, 112.10 OAL
Delta 282 Camshaft
AEM Cam Gear
Forged pistons (custom wiseco made to work with h22 eagle H beam rods)
Eagle H-beam forged rods
Things I have:
Fully built head;
-3 Angle Valve Job
-Flat Mill Decks
Delta 282 Camshaft
AEM Cam Gear
