anyone ever had a problem with their dsm manifold leaking at the block?? I had bought a copper exhaust manifold gasket and it had a raised lip and it seemed to be leaking to begin with. then I switched it out for the gasket that came with my aftermarket header and it still seems to be leaking. Could it be my manifold?? i kinda ported a little of the chambers out but just enough to take off some old carbon. i think i am tightening the bolts down enough. Its as tight as I can tighten it anyway. could it be that the manifold is crooked? i would think the tightneing of top and bottom bolts would even it off.
DSM manifold leak??
make sure you torque them down much like you would a head so its even pressure, also make sure all your mating surfaces are clean and free of debris.
ya i broke one out. it stripped the thread out of the block. But i put all the others on and i even bangen the wrench with a hammer to get some more leverage and it still seems to be leaking. I am going to try to get a new mani gasket n see if it helps.
1993 Honda Prelude H23t -big 16g turbo, uberdata, and a kick ass body and paint to go with it!
Don't use those crappy gaskets that come with aftermarket headers, Use the genuine Honda Metal gasket there. If you are tightening the studs down all the way and you are still having a problem then you might have indeed a warped manifold. Put a straight edge onto the manifold and check the straightness of it.
and check the stock manifold as well, who knows your head may be off...but usually thats where the gasket comes into play.
nice nice just try to get at the ends of the manifold with a dremel so that itll fit. and get placed nicely on the head if its got all that carbon and soot on the head and on the gasket and the manifold your gonna have to get a wirebrush and some sandpaper and get busy to try and get a nice clean surface.
