i have a auto h23 tranny and was wondering how it would handle boost or if it is even a good idea to boost it i also dont really want to spend too much on the shift kit
auto turbo
auto turbo
current cb 93 10th ann. edition
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973Tags: None
If you not looking for crazy 400+whp or drag race at every light, Boosting an auto for everyday driving is very pleasent to drives. From my experience and other source the Honda Auto tranny in good condition can handle 250whp easy. You will want to beef up when you hit above 300whp. It the darn axle that are the weakest link, I seen more engine get damage then auto tranny die when boosted. AUto have TQ converter which lockup so you can't rev high and drop the clutch like manual. High reving and heat kill Tranny not boost. Change your Auto tranny fluid and get a bigger external tranny oil cooler (the stock auto has a small tranny oil built in lower part of radiator).
Ps. No need for the shift kit, a healthy auto tranny will upshift in about .6sec and never miss. But racing auto tranny is more then just stomp on gas and race.
And again it you car so have fun with it... drive what you feel compoftable the most.
I have boost USDM F22a4, JDM F22A, JDM H22A and they all are Automatic.
Originally posted by whitejdmcb7i have a auto h23 tranny and was wondering how it would handle boost or if it is even a good idea to boost it i also dont really want to spend too much on the shift kit90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
build the tranny?????? how would u do that
for my case i weas only looking to push like 5-6 psi what is good to get on that site will the torqe converter suffice or do i need the whole bullet proof tranny kit
I'm comfortable with my auto tranny for N/A but not for boost right now as my daily driver. I know my tranny can't handle all the new torque it will get from a turbo setup. I'm going F22b (DOHC) pretty soon and I wanted to use my current F22a auto tranny too. For future projects and performance upgrades you will definitely want to upgrade your tranny first to prepare it for all the new hp and torque the turbo will produce especailly, if this is your daily diver. Right now I can't deal with a lot of down time for my ride. I have to do little by little so I don't break anything in perfect working condition including my tranny. The first thing I'm going to get for my tranny is going be the torque convertor when I start look for serious hp. I''ll keep building from there. There was this one guy on this site that had an f22a w/ auto tranny boosted using a OEM turbo from an Nissian 300 ZX. He said the tranny slipped like hell in 3rd and 4th gears.
Originally posted by whitejdmcb7for my case i weas only looking to push like 5-6 psi what is good to get on that site will the torqe converter suffice or do i need the whole bullet proof tranny kit
5-6psi on a normal size turbo say 14b will mostly produce at max 50hp/40TQ.
That is just fine on a stock H23 engine and tranny. You should check your auto tranny condition before you buy anything. Is the auto fluid cherry red? any burnt smell? Can the auto tranny upshift smoothly in everygear? well honda tranny 1-2 upshift is alway rough on auto. have you ever seen when you floor the gas your rev get real high but your tranny is not kicking down to lower gear or was unable to catch a gear for a bit?
Like I say if your tranny is in good condition(healthy) it can take an extra 50hp/40tq. Now if you tranny is sliping or seem like it extremly high millage over 170k, it cheaper to get a used JDM tranny for like $300-$500 that has low 50k-60k millage on it. Most of our Tranny are high millage already, no matter if you keep it NA or turbo it, NOS it will slip eventually above 200k miles. If you are going to boost I recommend geting an JDM H23 with LSD auto tranny for $500-$700. Cheaper then level 10 rebuid, it can hadle 300whp at the wheel and has much lower millages. A small fraction cost compare to a trany rebuilt and cost a bit more then getting a TQ conventor install.
After market tranny oil cooler, and regular trans oil change is all you need to run 5-6 psi on your auto tranny.
You don't really need a racing TQ convertor unless you do alot of stop and go racing. All it basically do is allow you hold rev higher when launching, stock is about 2k rpm.
YOu should be more worry about your engine when turboing unless your making over 300whp. many factor can make it go boom faster then sliping your auto tranny. lean condition from fuel pump,fuel pressure regulator, fuel injector, oil and vapor from the PVC system just to name a few. most people don't relise denation in their engine when racing until white smook coming out of the exhaust.
I have and still drive my current turbo AUtomatic car everyday to work and such for over 1 year now. The car treat you as you treat it.90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
my boss has a 1999 gsx eclipse, Automatic. his car is pushing 400 hp on a evo 3 turbo and lots of bolt ons.. we had to remove his tranny cooler because of the extremely large intercooler, well we put a smaller tranny cooler back on his,, so i took the one of the gsx and figured if it's good enough for a turbo car from the factory,, surely it's good for mine... the placement for this is key to get cold air...
i put it on mine and i have seen a big difference in how it shifts and the temp after you drive and then the car is turned off.
i to have constantly heard our tranny's will hold up well untill the 250-280 hp mark,, first to go is normal, the torque converter...
don't let people tell you that an auto tranny isn't good for boost....
this gsx from a launch already is pushing 3 psi,, AWD and this thing doesn't not slip in launch.
by 3000 rpm's it's at 15 psi, 4500 it's at 30 psi pegging the boost guage out and the whole time you are slammed in your seat----- your head=mush+adrinaliene X piss=big mess. and his tranny is factory...
i've seen some blow up a hundred times in a year and others live forever...Last edited by KeeleDesign; 07-06-2007, 09:28 AM."Self Renewed"
