whats up yall i am i progress of doing a mild f22 build (top end mostly cam springs retainers post etc) i was wondering what would be best if i delete the iab's or keep them cause i have two h23 manifolds one with the iab delete and the other with iab's any input would be appreciated
to iab or not to iab
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973Tags: None
I just did an experiment with a blacktrax spacer and iabs vs blacktrax spacer only, and I find that having no iabs yields a smoother transition into higher rpms, and better acceleration around the range where the iabs would be normally opening.There are no black and white suspension answers!!!!!!!!!!!
well iheard that having iabs yeilds more low end while deleting them will give u better top end power on a stock motor but with it built the iabs wouldnt do much for me is that what u guys are saying?
word thanks
Do you plan on exceeding or having your peak power above 7k? If you do, delete the iabs, it will give you up around 10-20 more cfm per cylinder of air. Otherwise leave them in, because it does help having them hooked up when driving around town. Also h23 runners are longer then a6 runners (a6 for top end, h23 for bottom end).
I keep them for a daily driver, under 3500rpm without them sounds cool but is weeeeeaaaak in the bottom end and has no throttle response. I'd run with no plate at all for a setup where you're only worried about high rpm, I think that's what most people are referring to and doing for max HP.
PM me and get it done right!
