Originally posted by nine_deuce
View Post
The Long Awaited Bisimoto Dyno!
This topic is closed.
It is unfortunate that my own brethren, using the same engine as in my race car, with all the research that we have done, would keep doubting our abilities.
It is not uncommon for such gains to be seen if a header or even intake is designed properly. I do not tape my research sessions for public viewing either.
That chart above is my 23rd iteration on the F22 design before I made one for 'Cisco. It was a bone stock F22A1, with a stock exhaust system and catalytic converter. Here are some examples of engines with smaller displacements, using our header designs:
- D16Z6 SOHC VTEC
- 0.5mm overbore, total displacement 1611cc.
- compression: 12.2:1
- Stage 3 cam, valve springs and titanium retainers
- Ported Head
- Magnecor 8,5mm spark plug wires
- ARP head studs
- ARP rod bolts
- Fidanza 7lbs flywheel
- Exedy Stage 1 clutch (upgrade)
- Edelbrock Performer X intake manifold
- Edelbrock cam gear
- B16A2 60mm throttle body
- AEM V2 Cold Air Intake
- AEM Tru-Power underdrive alternator pulley
- Power steering removed
- B&M fuel pressure regulator and gauge
- 2.25" cat
- GReddy EVO2 Cat-back
Comparison, Bisimoto header vs DC 4-2-1: result = 17.8 whp, 6 ft/lbs tq
Stock B16A (a small displacement, hard-to-show-header-power engine)
Ebay intake
2.5" exhaust system
Custom Bisimoto V2 vs custom $1100 header from popular competitor
Result: Bisimoto produced 18 whp at 7000 rpms and 12 ft/lbs at 6000 rpms, over more expensive competitor header.
The F22 is a higher displacement engine, and with appropriate camshaft upgrades and compression, it could so wonders.
We are scientists, and not shadetree mechanics or racers. It is sad that many of you do not know the potential of the F22A engine. For those who do, cheers!'Bisimoto D15/D16/F18/F22
World's Fastest and Quickest TRUE unibody all motor FWD
World's Fastest All Motor SOHC Honda
1988 CRX Unibody, D16 full street: 12.68 @ 107mph
1988 CRX Unibody, D15 full race: 10.77 @ 123mph
1988 CRX Unibody, F22A full race: 9.81 @ 139mph
2006 Insight Unibody, F22A: 9.26 @ 152mph
NEW!:www.bisimoto.com: parts, dyno tuning, apparel, technology!
Bisimoto's Facebook page
478 HP naturally aspirated F22A!!!
Well, I guess that pretty much ends that discussion, as this engine is representative of most of the engines on this site.
A peak gain of ~27 WHP seems the price seem like a screaming deal, especially with the stainless construction.
Relative gains based on the chart:
5WHP from 1500-3000RPM (+10% gain)
3WHP from 3000-3500RPM (tapering down to even)
-5WHP from 3500-4100RPM (a loss of about 5%)
+2WHP at 4250RPM
+8WHP at 5000RPM
+27WHP at 6300RPM
If this were tuned, or had additional mods to improve the flow, imagine the gains. Also, notice the much meatier bottom end torque curve, which is in some cases providing an additional 15-20% torque in the bottom end and is not tapering off as quickly in the top end.
The other advantage to this is that you won't have to shift as early, which would put you back into the meatiest part of the power band, where you can again make use of the improved powerband.
Originally posted by d112crzy View PostWhat size collector is on this header?
If you are referring to the output flange piping size (as most commonly refer to as the "collector") it ends with 2.5 inch.
I like it.DEVOTE
FS: Lokuputha's Stuff
Bisi, cmon, you gotta expect a little skepticality. These type of numbers have never been seen before from any other company to date. Its normal to want some kind of proof because in stock form, the engine is, well, sort of a dog. Yeh it can be wakened up but you woke it up with ONLY a header. That shit is amazing. Like they say, the proof is in the pudding, once your header hits the street and reality hits, the doubt you are referring to will dissappear. Chill and keep up the great work.
P.S. Give me 50% off on your H22 headers. Chill
Originally posted by CBAccordA4 View PostBisi, cmon, you gotta expect a little skepticality. These type of numbers have never been seen before from any other company to date.
great job man, good to see the results finally and gotta say im quite amazed..
keep up the good work brother
smoke tires, not drugs.
I mean, for one - he does own the highest HP NA F22.
His research into his products is well developed, and he has a special interest in the F22.
As far as I know he is the only person that has seriously experimented with the F22 in N/A form. The next person I know would be Cisco.
My 5.7 LS1 Holden Ute
This is truely amazing. I'm curious about how the D-series gains were previously shown in comparison to the F-series, as both motors are very similar, yet the shape of each header is totally different. Bisi, is the drastically different design on each for clearance purposes? I know each runner must be equal length, and the curvature doesn't matter much provided a proper diameter is used (as far as I know). I'm not asking for secrets or anything, I just would like a little info on the concept behind the design.There are no black and white suspension answers!!!!!!!!!!!
