cams for h23 non-vtec
    I am new here, and have just gotten my hands on a CB9 (91 Accord Wagon). I got a free h23 out of the deal and will be putting that in when I have time (hopefully within the month). Now, I am searching around online and not finding many options for cams. I may boost the motor down the road, but I want a slightly more aggressive set of cams. Are my only options to have them reground?
    The car already has I/H/E so it shouldn't be too bad, but you know how we are, always looking for more.
    - Phase 1ne, get off of lazy arse and put in h23, then do some bodywork and paint
    you know if you're boosting down the road, you'll need turbo cams or stock might work okay.
    but NA cams are made for longer duration & lift.
    so knowing that...you willing to spend money on NA cams now, & swap them out for turbo cams later?
    if so, talk to Delta camshaft & see if they can do a regrind on H23 cams. Then, you'll just need some upgraded valve springs
      hey cell, we should put a h22 head on that sucker i havent looked at it to hard but i have a h22 block in my basement and mabey we can get the oil squirters to work in the h23 block. give me a call and i will help you brainstorm-john
        why not just spend the time to P&P the H23 cyl head & the intake manifold as well with better NA cams or a regrind.
        but if you have time & can make it work, have the will....do it up, post any successful results
