Advice for Helical LSD trans: IMO definite read.
Originally posted by cbscandal View PostIf you're gonna swap an Mfactory FD in there, you might as well stuff in an F22 5th gear as well. Just a thought.
Also, I see a lot of mention in this thread about the M2B4 Tranny. Be careful when buying aftermarket parts for these because a lot of them specify that they "Don't fit LSD equipped models."
Good thread!
^Right, I have always been under the impression that you CANNOT add an aft. mkt. FD gearset to an OEM LSD tranny. Yet Shaun Van Beers installed the MFactory FD into a Euro R gearbox AKA T2W4 which is OEM LSD. I am going to assume that the M2B4, T2W4, T2T4, etc... all use the identical LSD or maybe they don't, IDK.
But I am curious since that FD was added to an OEM LSD tranny. Also, MFactory uses a USDM Prelude VTEC as an example for ETE, yet, the M2F4 is non-LSD. How could their FD unit fit both an M2F4 and a T2W4? 2 diff. designs maybe? Sorta thinking out loud here, I'll have to contact MFactory to see if they're stuff'll fit an M2B4.
And to GraniteCB7, yes all of them use the same lsd. The only H- series trans that didn't use the helical is the type-s preludes, that used the viscous lsd'91 Concord Metallic Blue. Status: under construction
Yeah, 4.6 looks to be the best compromise between acceleration and cruising RPM if you really want to upgrade the final drive. The 'after' video never gets old, that Prelude boogies. When I go to beef up my transmission, it'll be interesting to see if an Accord fifth gear will lower that 70mph RPM from 3900 for better mileage.
Watch this get moved to N/A, lol.
ED. - turbo cars can't turn.Last edited by CyborgGT; 04-19-2013, 04:57 PM.
