View Post
325whp 227wtq H22
While you weren't impressed with the horsepower, my concern was more so with the torque. Perhaps this is maybe because I'm not an expert/lack of experience, but I always assumed that with N/A builds would always have the numbers relatively close; I guess because that's all I've ever seen with my own eyes. I just figured a motor with 300 or so whp would have close to 280 or so wtq. Is that also a result of mix-matched parts?'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Congrats on hitting the 325.6 WHP 227.3WTQ range. I'm sure you will be able to squeeze even more out of that thing. Seems like every time you post there is another 40-50whp found.Last edited by GhostAccord; 02-26-2011, 03:29 PM.
Don't beat yourself up. What you have there is an accomplishment by far, something that gives others inspiration, and a gateway of hope for many; you understand!
With that being said, from mine and possibly other's perspective, amazing job. Great build. I am very impressed and enthused. Keep up the good work as you've succeeded extraordinarily. A pat on the back is well deserved.The Lord watches over me!
- D. Chappelle
Originally posted by dbsharp View PostWhen you make peak power around 8500 rpms, you will never have close hp and torque numbers.'94 JDM H22A: 178whp 146wtq
180-190ft-lbs torque, ~80% of peak developed below 5500 rpms! These low rod ratios are autocross motors no doubt! This motor in a civic would rape turbo cars out of corners! For a drag application, why not make the rod ratio higher, spin the motor faster and make more peak power?
Awesome numbers!There are no black and white suspension answers!!!!!!!!!!!
Originally posted by mndude07 View PostFor a drag application, why not make the rod ratio higher, spin the motor faster and make more peak power?
Awesome numbers!
Originally posted by gloryaccordy View PostGreat #s, but w/2.5L, 15:1 comp and your expertise its to be expected....
Kinda curious to see what you could do w/a stock block H...
P'n'P head
Bisi stg 2 cams
Bisi header
2.5in exhaust
maybe even an IM swap w/ CAI
All with a tune, of course.
Originally posted by nate'sCB7 View PostWith a stock block you can still make a good amount of power.
P'n'P head
Bisi stg 2 cams
Bisi header
2.5in exhaust
Originally posted by mndude07 View Post180-190ft-lbs torque, ~80% of peak developed below 5500 rpms! These low rod ratios are autocross motors no doubt! This motor in a civic would rape turbo cars out of corners! For a drag application, why not make the rod ratio higher, spin the motor faster and make more peak power?
Awesome numbers!
