Most Powerful Naturally Aspirated CB7 List
This is a sticky topic.
    K&N filter
    BLOX 4" velocity stack
    AEM BB6 V2 SRI
    Maxbore 70mm>64mm H23vtec throttle body
    Skunk2 Pro series V2 H22 intake manifold
    OEM RDX 410cc injectors
    AEM adjustable FPR set at 40psi
    PT3 (F22A) cylinder head milled .020" (bumps compression to 9.7:1)
    Bisimoto level 2 regrind
    Bisimoto Pro valve springs
    Bisimoto billet aluminum rocker spacers
    Bisimoto cam gear
    JDM F23A short block
    Bisimoto V2 4-1 header
    Ktellar 2.5" exhaust piping kit
    Vibrant super quiet resonator
    Xforce varex dual tip muffler
    M2S4 trans
      He y joey where's my bump, lol.
        Pssh...I'm busy kiddo.
        The F23A bottom was stock?
        '94 JDM H22A: 178whp 146wtq
        If you say double dutch rudder, i'm banning you...
          Congrats on the new spot jdm92_accorn. Show those DOHC boys what a single slammer can do.
            All oem, 24k miles according to the paper work.
              Turned into H builds
              Originally posted by SOHC-FTW View Post
              Should separate H and F or this whole thread will be nothing but bolt on H22a's which we've all seen a million times.
              What i suggest is make a top 5 for each F&H then the top KING's with both top 5's combined.
              Just an idea.
              x2
              4000watts just so all the haters hear me comin!
                So my brother wanted to know if the engine has to be honda. He is thinking about putting a SR23VE in a CB with a 6spd from a spec v.
                  He needs to be an active member... Aside from that all the rules state is he must provide dyno sheet and it has to be in a cb
                    he is a member. once he gets the car im sure he'll be more active.
                      Originally posted by NWaccord View Post
                      Great numbers guys
                      As the rule states, Your engine needs to be in working condition & in a CB. So with that said my spot should be taken down as I don't have an NA setup in my CB as of 7/21/13. I will be switching over to the dark side (boost)
                      Request Granted. You will be our first archived build.
                      He must be an active member as he said; but I'll allow the Nissan Engine, however puny it may be.
                        Lol, I told him he'd have to step up his game, 155-160whp is very easily obtainable with the f22's so he's going to need more than bolt-ons.
                          Same setup. More fuel, little less timing.
                          K&N filter
                          AEM BB6 V2 SRI
                          Bisimoto cam gear
                          M2S4 trans
                            Still gotta post the whole setup....
                              Done deal sir.
                                you planning to seperate the f's and h's?
