Prelude H23 eBay Intake tube
Blox aluminum velocity stack
AEM 6" dryflow filter
JVT "long tube" 4-2-1 header
2.25" test pipe+exhaust, 14" x 6" x 2.25" ID Magnaflow muffler
Timmytuning F23A1 chip/map/tune on a P28+ OBD2A to OBD1 jumper
62mm TB port-matched upper
Bisimoto intake manifold gasket
62mm H23A VTEC throttle body
thermal TB gasket
IAT sensor moved to intake piping
Car is crazy rich past 5K(AFR's in the 10's), and VTEC needs set at about 3200RPM. Lots of power left to be made by dialing stuff in. Going to add a ported/gutted F23 lower plenum/runners, chop up/ modify my H2B PLM 4-2-1 header, 3" exhaust, add the cam gear and retune. Total in mods+engine there's MAYBE $600 into this thing.
Two different B18C1 powered cars with bolt ons/tunes made 140-145whp/115-120whtq on the same dyno under similar conditions within the past week. My car door bangs with both of them.
