I came up with brilliant idea, can you just stick a air filter on your intake manifold. Would I lose horsepower, or gain? This idea probably sounds stupid but hey it might work
Air Intake No Piping Question???
that could work but, as 93Ex said..d air in der is too damn hot to suck into the manifold..but yeah if you put a hole on your hood and put a hood scoopp then that would probably work.."
Fast and cheap won't be reliable
Cheap and reliable won't be fast.
And fast and reliable won't be cheap"
~EYCEE~
Originally posted by AcclipseH23Your torque may increase. And i said may increase, but i think that horsepower will definitely decrease.
A longer/smaller diameter intake (CAI) or long runners will bring out maximum torque in the low-mid but HP numbers would go down alittle.
So the filter directly on the T/B would give more HP at the high end and the torque numbers would go down.
Originally posted by Granite CB7I think you MAY have it backwards, please correct me if I'm wrong: Short runners (such as ITB's) or a short/bigger diameter intake (short ram) will help in the high end w/ gains in HP but a loss in torque, b/c torque is down in the low-mid range.
Originally posted by AcclipseH23The whole purpose of the intake pipe is to get away from the hot engine bay. Putting a filter on the tb will definitely increase the response, thus i theorized the torque increase. But in high end the filter on the TB wont carry as much air velocity as the short ram so i figured there wont bemuch of a hp increase.
I've heard this many times, in general torque is on the low end and horsepower is on the high end. A B18C5 revs like crazy, and makes good HP b/c of the revs creating rotational kinetic energy. It doesn't put out good torque b/c torque is down on the low end and it's a high revving motor. Any V8 usually makes amazing torque, and it's mostly on the low end, but HP wise, not as much b/c most don't need to rev that high to make power.
So, from what I've learned (I'm not an expert) these will help for the following:
High end HP- ITB's or a 4-1 header
Low end Torque-CAI or a 4-2-1 header or even a long flowing intake manifold
The length and diameter of the runners on an intake, intake manifold, or a header can greatly alter where the engine makes it's best power.
Someone please jump in and correct me if I'm wrong at all! Just trying to share
who cares just dont run a filter at all, what kind of water hose is that?H22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
