H23a vtec
68mm tb
Euro-R intake manifold with euro-R cams
Highend header 2 1/2" exhaust
750 injectors on e85
Stock block
Dry shot with .040 pill.
262hp/252tq
The Official Nitrous Build Thread
f22a1
Stock to my knowledge except for:
Exospeed stage one cam
SRI with a Tsudo mushroom filter
Spyder Automotive header, cat, 60 mm stainless exhaust
Cold Fusion wet kit, currently set up for a 50 shot
Timing retarded one degree
195/60/15 Potenza G009 on the front
163 whp off the bottle
Installed it a few months ago. Haven't sprayed her yet.
Off the bottle, she runs 15.87 @ 88.4
Leave a comment:
Stock F20c1 head and block
Stock injectors
Stock fuel pump
Stock untuned ECU
Stock intake with K&N drop-in filter
Less than OEM grade tires-Kuhmo Ecsta ASX
Invidia test pipe
70 flywheel shot of nitrous- NOS 5120 dry kit
Best run at KCIR with a clutch starting to slip was a 13.3@106 with a 2.0 60'
Also ran a 13.5@107 and a 13.7@105
Click on the pictures to make them full size
Now I have added a Megan replica header and an AEM EMS standalone ECU. I will be getting an ACT 6 puck clutch and tune myself for a 125whp shot for next season.
Leave a comment:
Mine is H23A1 but in my lude, but anyone with an H23A1 in their cb7 can use it as a reference.
Setup:
Engine 2.3L H23A1
Crower Stage 1 Cams
NGK Iridium One step colder Plugs
NGK Plug Wires
Max Bore TB
BB6 Type-S Intake
DC Header
2.5" Exhaust
NOS Wet kit w/ Purge Valve
60 Shot jet
P06 ECU
Its fully tuned using Neptune RTP
Dyno:
Leave a comment:
If you're running nitrous, post up! This thread is dedicated to all who are spraying, even on stock engines. If you've got an all out N/A build with spray, or just basic bolt-ons, this is for you.
Post your setup, dyno numbers, and 1/4 and 60ft time. Also include a picture of your engine bay, so we can see what you're working with.
Also include a description of the tuning you've done in order to run the spray. Example, timing retardation, spark plugs, ECU tuning, etc.
Bottle Fed Motors FTW!
Leave a comment:
