soon ill be getting an h22 and i plan on running turbo on it but id like to spray it too(a small shot)...and for turbo i know its best to keep the compression pretty low..and for nitrios i know that for percaution its good to upgrade ur fuel system, and internals(correct?) and that would be rasing the compression (correct?)..so really wat im asking and i guess its pretty noobish,,can u run turbo and nitrios together? and if so, how so?
?bottle and boost?
Yeah you can do both. It helps to spool a big turbo up for that extra off the line power. building the internals of your engine doesn't increase compression. lol Just build it up for turbo and if you need more power then add nitrous.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
Originally posted by koolkoreankedYeah you can do both. It helps to spool a big turbo up for that extra off the line power. building the internals of your engine doesn't increase compression. lol Just build it up for turbo and if you need more power then add nitrous.
Originally posted by Mikewat about the fuel system? i know with a small shot the stock
system is fine but wat about a 100 shot?Oil leak?What oil leak? That's just sweat from all that horsepower!
