ive read about the laughin gas....
  • Shadow1
    replied
    Originally posted by midnite racer x
    It depends on the compression of the motor, the octane fuel you wish to use, and how much the ignition timing is advanced. Stop saying advanced timing tho because there are many types of timing. The timing your refering to is the igntion timing. Generally your supposed to retard the ignition timing about 1-2 degree per 50-75 shot of nitrous. The point of it is to decrease the chances of detonation which can either be accomplished by higher octane fuel, retarding the ign. timing or having low compression in the first place.
    Nitrous seems to love 11:1 compression and thats the compression most ppl run when they choose that route. In their case, yes, advancing the ignition could do some heavy damage to the internals...they need to retard the ignition accordingly.
    thank you for answering my question. and you to mike.
    Leave a comment:
  • NoSloCB7
    replied
    I was going to post unitl I realized Antoine said everything I was going to. I agree.
    Leave a comment:
  • starkrice
    replied
    haha i love this thread
    Leave a comment:
  • MRX
    replied
    Originally posted by Shadow1
    ok NONE of yall read what i typed. i asked can i put nitrous on a car that has advanced timing on it. i kno u can get HP from advancing the timing.
    Leave a comment:
  • Mike
    replied
    i have read in the JCWhitny book that you shouldnt use Nitrous with mods that advance your timing. but whats he point when most of if not all of the cars out there that are modded hav some kind of advancement on the engine. if i get new cam gears can i use nitrous w/o worring about it messin up my motor?
    ok.......yes most cars that have nitrios on there car have advancements on there engine...but they dont have advance timing becuase yes avanced timing like jcwhitney said is bad for nitrios...if u got new cam gears it would not mess it up becuase on the cam gear it self it has an adjustment that enables u to adavnce or retard ur timing.....u can keep it at stock timming and it will be fine...but it helps if u retard ur timing a littlebit but. it is not needed unless ur running a very large shot or if ur full out racing not so much for a good a idea for a daily driver
    Leave a comment:
  • Shadow1
    replied
    ok NONE of yall read what i typed. i asked can i out nitrous on a car that has advanced timing on it. i kno u can get HP from advancing the timing.
    Leave a comment:
  • Dirty Harry
    replied
    Be my guest
    Leave a comment:
  • Mike
    replied
    haha can i use that as a quote in my sig?
    Leave a comment:
  • Dirty Harry
    replied
    Please research more. You shouldn't even be thinking about using nitrous if you have to ask these questions. JCWhitney puts that in the advertisement as an idiot-safety warning, kind of like "WARNING: DO NOT INSERT GENITALS INTO BLENDER"
    Leave a comment:
  • Mike
    replied
    advancing ur engine (puting performance parts in ur engine) is differnt from advance the timing
    Leave a comment:
  • Mike
    replied
    no...wat i ment is.....its sounds like hes misunderstanding jcwhitney thinkin advace timing has to do with adding horse power or sumthing
    Leave a comment:
  • Ilikebigbutts
    replied
    Originally posted by Mike
    advance timing is differnt from advancing ur engine.....
    Advanced igntion timing and Advanced valve timing.They are both bad for nitrous.
    Leave a comment:
  • Mike
    replied
    advance timing is completley differnt from advancing ur engine........i dont much about nitrios but from wat i gather....u dont have to unless ur goin with a crazy big shot but like ilbb said if u get adjustable cam grears its good to retard ur timing a lil bit
    Leave a comment:
  • Ilikebigbutts
    replied
    you can retard your timing with camgears...
    ILBB
    Leave a comment:
  • Shadow1
    started a topic ive read about the laughin gas....
