Hello, is there anyone out there aware of a manufacturer that makes extended tie rod ends for the cb chassis or equivalent? I had my toe zeroed once after I did my drop, but there is deffinately not as many threads left on the rod end and it bothers me. I'm sure I could rig up some sort of male-female threaded spacer to put in their, but something already on the market would be easier and safer. I have searched already so thanks to anyone who could point me in the right direction.
Extended outer tie rods
Are you really short on threads? Even if you were absolutely dumped, w/ all honda components, you'd still have 1 to 1 1/4" of threads inside the OTR, which is alot, you should be fine. I had to bump the toe out on my CB 3/16" on each side w/ my drop, still plenty of threads left! If you'll never feel good about it, weld on some M14 X 1.5 jam nuts to the OTR. If you're actually going to do this, make sure the threads orientation is correct using either the inner tie rod or a sample M14 bolt. Tighten a nut against the OTR but not too tight, then tack weld it. Make sure it threads easily, you'll still be using the stock jam nut to lock your alignment in.Last edited by Granite CB7; 12-19-2012, 07:10 PM.
Originally posted by wed3k View Postif your alignment is within spec, why would it matter?
