Originally posted by cb7 calling
View Post
I don't want to delete this because I want to make sure people see it not working here.
As for using CB Uppers, yes, I am certain. I went to the yard and grabbed good looking OEM uppers to throw the SPC balljoints into.
I had absolutely no issues with axle fitment into those newer knuckles though, nor any other fitment aside from camber being way too positive and knuckle to spring clearance.
I don't want to take these knuckles that I have on the car currently back off, but I will say these are WAY different in shape and size than the newer Accord knuckles that I was using.
The brake line rubbed the shock hard when you'd turn the steering wheel. The knuckle itself would rub as well. And even hitting the damper I would get positive camber.
And it clearly doesn't work. I should have the same suspension your friend does. Roughly, anyway. Why it fits on his 97, and doesn't fit on my 93, I don't know. I considered it was lower control arm length, but I already had my front width as wide if not wider than the rear, and I also got those off of a junkyard CB and they looked fine in the yard.
I'm more than willing to get any pictures or anything that might help aid this discussion though.
Leave a comment:
