F20B soch VTEC
    F20B soch VTEC
    I noticed the stock f22 mount bracket doesnt fit the F20b. So I've been Driving for a year. With stock f20b bracket being held by one bolt. Now I found out a year later that I needed was the F22B1 Left Vtec Mount(DRiver side) and now its being held on rite.
    1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
    some searching would have helped
    the same time u learned
    Just do what PR CB7 said.
      im using the stock bracket on mine, sure i cant put the safty on the punt cause that hole doesnt like up, but the only reason they dont fit right is one mount is like this )l and the other is l(, i need to get one made ill as rosko to make me one since it should be too hard for him, i just need to send him a mount to refrence off of, and a picture of the mount location with specs
      edit: wait wait wait you mean the f22b1 mount bolt up to the engine and fits the stock cb mount?
      PSN ID's:Tidashoni
      1992 Accord EX Coupe
      My FS Thread
      Not so DD 2013 Subaru Impreza WRX STI
      Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
        ^He's referring to the F20B SOHC motor, basically an 88mm stroke F22B1, this motor and your F20B DOHC may have some differences, I believe.
          yea i know, im gonna take a look at my bros ex cd and see, and if the mount looks like my f20b mounting spot then ill have to run and grab one
          PSN ID's:Tidashoni
          My FS Thread
            This is how the mount looks like.
              ohhh your talkin bout that part, well guess ill have to see if i can find another dohc f20 braket
              PSN ID's:Tidashoni
              My FS Thread
                Another suggestion....
                Hey i know about that F22B SOHC Vtec mount and that is the mount from that car... but what I did is very simple for a friends car..
                I took off the motor mount and bracket from the F22A6 and then took off the F20B motor mount and bracket and replacement it with the original F22A6pair...
                See if that is any help...
                  A6 bracket doesnt bolt up with the F20B. I have a spare bracket and didnt work.
                    I am......
                    .....fukin curious as hell to know how good does this bitch pulls @ high rpm, cuz my 2.0 with 11.5 fw has some balls, and u have vtec it has to crack like a mofo meng, I got a f22a trans I need a H
                      It pulls hard and the motor is loud, the car sounds beefy. But to get it running normal I had to use a POA ECU from a 94-96 accord VTEC. Then Swap the Intake manifold for a F22B1 Manifold. Also use a F22B1/B2 Motor mount for Driver side. But yeah It has balls and revs stock at 7.2 RPM. I'm using the F22a stock Manual Tranny. I want a H series Tranny Type S but its hard to find.
                        SOHC don't crack shit.
                        wat?
                          yup, being as it only has 150hp, try out the dohc sir-t version
                          PSN ID's:Tidashoni
                          My FS Thread
                            lawls
                            Past 1990 Accord EX Sedan
                            Past 1990 Accord LX Sedan
                            Past 1991 Accord LX Sedan
                            Past 1993 Accord LX Wagon
                            Current 1991 Accord EX Wagon
                              Yaya
