Hi all!
I have my swap in my car finally, it's an h22a4 into a 92 lx coupe. I have swapped over to obd1 fuel injectors, distributor, and ECU.
The Engine cranks over but wont start, wont even cough, I pulled a spark plug lead and have no spark, I pulled the fuel line and I have no fuel pressure.
I was reading through the service manuals for 4th and 5th gen preludes as well as my accord, I see that for the preludes there is an engine harness ground on the thermostat housing under the distributor near the back of the engine on the side, there is also a much larger ground on the transmission underneath the starter.
For the accord there is a engine ground on the thermostat which is closer to the front of the engine on the side, on my second accord (also a 92 lx coupe) I see the ground runs from the thermostat to the battery not to the engine harness but idk if that's correct since the previous owner fancied himself a home electrician and monkeyed with a lot of the wiring.
I looked at the accord harness I have on the H22 and I cant find a ground wire that would go to the thermostat but I might have missed it.
Is the accord harness supposed to have a ground wire attached to the thermostat on the H22?
Are there any other grounds I could have missed that could be causing my issue? I have the transmission grounded to the battery underneath the starter and I have the PS bracket and Valve cover grounded to the left side of the engine bay above the engine mount.
Thanks in advance and let me know if you have any other ideas as to why I have no fuel or spark, I checked all my fuses, (currently using the ignition coil that came with my h22a4, should I be using my accord's?)
