i swapped an h22 into my car recently and when i was driving it around the first day i got it working the crank pulley rattled loose and almost fell off...i had a lightweight underdrive pulley...so i put it back on but it kept coming off...so i decided to put the stock pulley back on...then the other week i was driving it and it started to make a noise around 3700 rpm...i thought it was my transmission so i took it to a transmission shop and they told me that it wasnt the transmission it was noise from the balance shaft...then he told me that the shaft was out of time and i needed a new timing belt because when my pulley came off the timing belt slipped...after he fixes all this he tells me that there is still noise from the balance shaft...now i have a few questions...has anyone ever had this happen to them? does the balance shaft have bearings that could have been bad? any information would help...
balance shaft trouble
It won't hurt anything.
I have done it many times and driven the cars many miles. So have many others.
All the balance shafts due is cancel the vibrations that are common to all I-4 cylinder engines.
It will free a little bit of power, and won't really increase the vibration much. Honda's are pretty well balanced from the factory which keeps them from being nasty with the belt off.
You may notice a little more texture in the steering wheel or pedals, much like the vibration on a vibrating sander (not as bad though). Your passengers won't feel a thing and you will be adjusted within a day.
A valve adjustment or bad engine mount will have a much larger effect on vibration than the balance belt.
It was something Honda did to make the engines that much smoother.
do i have to remove the shafts to stop the noise? or just remove the belt? cause if all i have to do is remove the belt then i will...also if the bearing on the balance shaft is out of the block will that make noise when i drive?...thanks for the helpLast edited by accord93racer; 07-21-2006, 07:35 PM.
Originally posted by accord93racerdo i have to remove the shafts to stop the noise? or just remove the belt? cause if all i have to do is remove the belt then i will...also if the bearing on the balance shaft is out of the block will that make noise when i drive?...thanks for the help
Just get rid of the belt.
No matter what is wrong with the balance shaft, once you remove that belt, it will no longer spin, so bearings and noises will no longer be an issue.
actually the balance shafts cancel second order vibrations that are inherent in all inline 4 engines.
as far as imbalances in the crank....there are not much there to start with. A good example is the high milage crank I just has polished, and turned sue to mild scoring. when being balance after that there was nothing to be done, its balance was already excellent.
Originally posted by v4lu3sactually the balance shafts cancel second order vibrations that are inherent in all inline 4 engines.
as far as imbalances in the crank....there are not much there to start with. A good example is the high milage crank I just has polished, and turned sue to mild scoring. when being balance after that there was nothing to be done, its balance was already excellent.Originally posted by owequititAll the balance shafts due is cancel the vibrations that are common to all I-4 cylinder engines.
Pretty much what I said... If there is a large imbalance in the rotating assembly, then the forces involved in 2nd order vibration are increased. The same can be said with a larger displacement, which is why 4 cylinders of larger displacement are more likely to feature them.
But the force analysis, and what second order vibration is, is beyond the scope of this thread.
