Bigger Brake Booster swap
    I was wonder what brake booster is bigger and will fit an 9091 ex w/o abs
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    Basically, the 90-93 Accords that have rear drum brakes have a smaller brake booster and smaller brake master cylinder. Larger is had for both parts on the vehicle with 4-wheel disc/ABS.
    So look for a 91 or 93 Accord SE, 92-93 EX or 93 10th anniv. LX
      Is there a way that I can plug up the master cylinder abs ports, or what about a 91 wagon or di those come with abs also I really want to do this.
      NEW CB
      new
        IIRC the Prelude VTEC has a 1 inch MC and the EX/SE accords are 15/16ths. That'll prob. help a bit in clamping force.
        member's ride thread
        91 Accord SE 176k
          Does it have abs?
          NEW CB
          new
            Originally posted by Darkcloud View Post
            Does it have abs?
            yeah the prelude VTECs came w/ ABS
            91 Accord SE 176k
              How can I plug the abs ports since I don't have abs.
              NEW CB
              new
                  Originally posted by mj213 View Post
                  lulz.
                  smoke tires, not drugs.
                    Yeah funny, I'm being serious though and need this info asap before Sat.
                    So if you don't have info don't post please thank you
                    NEW CB
                    new
                      i could always bolt + jb weld it
                      and u gotta admit the buttplug was quite funny
                      oh also a side note. all 4g preludes WITH ABS have a 1" brake master cyl.
                      you can further research on preludepower.com
                      frostwhite225@gmail.com =VENMO
                      http://www.youtube.com/watch?v=NOB38zJu66o
                      [COLOR="Magenta"]
                        W/ either the VTEC m/c or the EX/SE m/c, you wouldn't be plugging anything at all, those still have 2 outlets, only difference is the rear flare fitting is larger, M12 compared to M10, like the front flare fitting. What you need to do is pull off the line that goes to the rear fitting on the m/c and flare on the M12 ABS fitting, all the ABS Honda's use them @ the m/c. If you're not up for that, I could def. make one up for you, I've done this afew times now for my ABS removal and H22Wagon93 and I sold an ABS removal package not too long ago w/ this modded line. If you have the fitting and you can flare, you can do this very easily Please LMK if you need me to clarify anything.
                        Oh, also, now is a great time to swap to a 4040 prop. valve if you haven't already!
