New Clutch Install Question
  • Granite CB7
    replied
    Yes, clean that all off very well! I might add: A very light and I mean light coat of grease on the input shaft is good for slight disk movement back and forth. Very light, even take a small flathead screw driver and scrape out all the splines so it's a consistent layer of grease. Do a good job greasing for the throw out bearing and fork too, it all results in a smooth operation that you can feel through the pedal believe it or not. Also make sure your rear main seal is good to go too.
    Leave a comment:
  • Night Wolf
    replied
    you get it also on rotors. remove it with brake cleaner. nothing else! & make sure your fingers dont touch the surface afterwards
    Leave a comment:
  • chrischhorn
    started a topic New Clutch Install Question
    Just bought a brand new Stage 4 Competition Clutch and 9.5lb flywheel for my h22. They have a light coat of grease on the pressure plate and flywheel and from what I've searched and read, its some sort of anti-rust grease or something. So my question is, should i leave it on there? cause I'm kind of worried about the grease making it slip. Or should i just go ahead and just clean it off with some brake cleaner?
