Problem starting after stall
    on a cold start, it starts up fine. when im driving around and turn the car off, and then restart... its fine. but sometimes when the car is initially warming up, and it fully warms up... the rpms drop as they should. but sometimes my rpms drop a tad too much into the 500's for a second. most of the time they will dip down and them come back up steady to mid 700's. but when it does stall out. restarting is always difficult. i completely turn the car off and try to restart, but it takes a few seconds ALWAYS. it turns over at a normal pace, doesnt sound like when the battery is low, but it just doesnt start.
    when it does finally start again, it stumbles in the low 500-600's for a second or so, and then raises up to normal. why do i only have problems restarting after a stall? under normal conditions i can turn off and start all day with no hesitation.
    i had this problem, i would start it fine on first try, after it was at normal temp and driven for a little bit, i shut off go back say minute later or not even, while the car is still nice and hot i would go and try to start, RPM's would jump to normal starting rpms and then just sputter and shut off, then i would try and try to start it back up but wouldnt, then i would let it sit for a couple minutes and it would fire up, but with a nasty low idle...but my problems why it did this where
    1. oil soaked plugs
    2. fowled plugs
    3. needed A MAJOR IDLE adjust <---- main problem
    after fixing all of that, i can run her hard, shut her off and she will fire right up, the idle was my MAJOR MAJOR problem, the others just added to the hassle.
    ^sold
      could u be running that rich at idle? to cause it to flood? making it difficult to restart.. and once it did restart it would take a few seconds to get rid of the fuel.. makes sense.. u need sometuning dood..
      Praise The Lowered...
        You might want to have your main relay checked out.....This is a common problem in our cars and it will cause problems like this...
        1991 Honda Accord Ex
        Pics of the beast!
        ::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
        2003 BMW 330I Sport.....Daily Hustler....
        Road Race #1
        Totoro Squad #2
          I agree check the main relay.
            thats what i was thinking, but i didnt really have any facts to make that assumption.
            and ive had my relay resoldered before cause it was messed up. but i dont think it would be causing it this time. cause its only on a stall restart, whether or not its on a hot or cold start. and it doesnt matter if its hot or cold... if i start the car normally without having just stalled, it always starts fine.
              Originally posted by fizzbob7
              i think it's a main relay too
              really? it can cause it not to restart after a stall ONLY. and it does turn over normally, just doesnt start. last time i had a main relay problem the car wouldnt even turn over
                I dont think its the relay
                Dynamic racing
                Look out for 4 point cb7 strut bars for dohc!!!
                bleh... i just put like 5 ounces of vodka in a 12 oz cup of mango iced tea...
                  Pretty Much all of the 90-93 Accords down here in Tucson that I know of have had their main relays replaced because of problems like this....My accord especially has had this problem....but it occoured at extremely random times. It always started right up when it was cold, but in the warmer weather, or when the car was warmed up, I would sometimes accidently stall it, or park it somewhere for a few minutes and when I tried to start it back up, it didn't start. I thought it was a bad tune or something, but I looked into it some more, and I found out that it was my main relay, so I replaced it and I haven't had any more problems with my car starting.
                  Pics of the beast!
                  Road Race #1
                  Totoro Squad #2
                    With what you've explained, it's not the main relay. If it doesn't matter if it's hot or cold there's no way that it's your main relay.
                    it sounds to me like it's either running rich, or a timing issue.
                    --JDM F22A--
                    JDM schmeDM, these lights are DIY-DM.
                      I did actually have the timing checked, but it was dead on, and of course H22s always run rich no matter what, but that wasn't the problem. When I turned the Key to the on position, I recieved no fuel Pressure according to the Fuel Pressure Gauge....And my Fuel Pump was brand new. I asked Scott aka 2point6 about the issue, and we solved the problem by putting in a new main relay.....I'm not saying that your wrong but this is what I found effective, and I haven't had a problem since.
                      Pics of the beast!
                      Road Race #1
                      Totoro Squad #2
                        the timing is advanced a little over stock spec, and i probably am running rich. guess ill eliminate one of those options after i get retuned.
