my car runs mint when nice out.but when there is moisture in the air it wont start.no spark at all its getting fuel.new ignition coil,cap,rotor,wires, distributer,igniter what else could it be???????????
No spark when raining or moisture
guess im gonna give up. ill never buy another honda again.this is retarted I have brought this car to 6 mechanics,2 dealers and been without a car for 1 month.and in the 1 month i have posted this on this site no one can seem to help me.up 2 $900 in parts still wont start when there is moisture in the air.WTF
Damn, I wish I had an answer for you, but I don't. Just some words of encouragement...don't give up, it's prob something small. I had a bad experience with my motor after installing it and looked everywhere for answers as to why it kept dying. Little did I know that it was the main relay. I always say "now that all the big and expensive parts are replaced, it's gotta be something small and simple, and although I don't know what it is, I know I'm almost there".
Couldn't of been done without you guys
Thats really weird man...I'm gonna go with what I would do and make sure that none of the wires leading to the coil, or any other ignition part are frayed, fried, or just shitty. It could be as easy as splicing in a new wire, good luck man. I hope you get it fixed. Hondas are great cars, I have had very few major problems and I've had 3.1996 Jeep Grand Cherokee Laredo
4.0L I-6 2WD
293k miles, still running strong.
Freshly rebuilt transmission.
its the cap and seal
hey your getting moisture in the cap which short your spark out. get a new cap with seal. that should fix it.
oh and one more thing. make sure your battery cable and ground arent gettting wet either. make sure connections are clean.
others area might be bad alternator which can slowly dischage battery causing no start no spark.
other problem would be bad starter or starter solenoid. use ohmmeter to check current.
also the ignition switch itself could be bad. where you put the key in. or fusible link.
oh and how did you replace the tdc sensor as you stated when the helms manual say the whole unit has to be replaced. say the tdc/crank/cyl sensor is a single unit and must be replaced as one unit.is your distrubtor new or old one you replaced parts with.
just some idead to get you thinkingLast edited by xfactortype1; 04-05-2005, 09:05 PM.
this morning i tryed to start again no luck.the weird thing is i get no fuel or spark. after cranking it for awhile i finaly get gas then if i keep trying for like 30 min ill get spark i really think the ecu is crap. the ecu has 210,000k on it my engine has 60k on it.yesterday i did new cap and seal,new wires,new ignition switch..no check engine light.today is my birthday, this suxxxxxx
Originally posted by Sho NuffDid you change your main relay?1991 Honda Accord Ex
Pics of the beast!
::::198.4 WHP and 146.6 WTQ Currently weighing in at 2700lbs...best time: 14.8@92mph::::
2003 BMW 330I Sport.....Daily Hustler....
Road Race #1
Totoro Squad #2
Originally posted by 4doorex93guess im gonna give up. ill never buy another honda again.this is retarted...WTF
Now that you got it running right, go check your thread on the leaky oil pan gasket.Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
