90 EX Distributer Bearing
    What is the Honda part number or where might I find the bearing NEW. I have looked on Honda part stores but it shows up as (blank) assembly and not the individual part.
    Be unique, like every other person.
    CB7 Sold________________________E34 Sold________________________E39 Current
    If you know the size of bearing you need, you could look it up here.
    http://www.timken.com/en-us/Knowledg...artNumber.aspx
    A&P-IA
      Not sure on the size, but using a ruler is not a foreign concept to me.
        Using a ruler wont cut it.
        A good quality micrometer along with T-Gauge or a digital caliper is called for.
        A&P-IA
          That small of a difference between Honda bearings?
          Edit: Forgot these are custom made did not think that one through.
            30105-60011252RS - 12.454mm X 28mm X 8mm
            Suits - TD30U TD31U, TD42U, TD55U, TD58U, TD60U TD41U
            Take the old bearing into a bearing shop, They will be able to match a replacement.
            My 5.7 LS1 Holden Ute
