what is the fuel pressure
  • Accord problems
    replied
    the first three time's was like pancake syrup . by the third time it was like a light surger free syrup . after that it was all cleared up because i actually took the line and ran it to a bucket till it cleared up . the last two and seconded set of plugs where as a preventive measurements . this stuff that came out was dark like a black crayon . its all cleared up now and if it does it again then i will order all fuel system replacements .
    Leave a comment:
  • Fleetw00d
    replied
    You changed the filter a total of five times? Was it clogging with stuff or were you just being overly cautious? If you're getting all sorts of debris from the tank, it may be time to find one in better shape. The tank isn't that hard to replace as long as the strap bolts come out.
    Leave a comment:
  • Accord problems
    replied
    i did the fuel cleaner . in order for the car to stay running during the first fuel treatment i went through 3 fuel filters and 1 set of plugs for one tank . second time only one fuel filter no plugs . 3rd time did not require fuel filter or plugs but i changed them any way's . this was about 4 months ago ..
    EDIT: the treatment Lucas Oil injector cleaner and fuel conditioner . i bought the one gallon .
    Leave a comment:
  • Fleetw00d
    replied
    Originally posted by Accord problems View Post
    fleetw00d thanks man . i just determined that i have two injectors stuck open is at 29 psi . when i shut off the car psi plopped down to 20 psi and still falling . but i fixed it i removed all in injectors then turned key on 2 and 3 just kept on pissing out fuel and would not stop . so i just replaced all injectors . no she stays at 42 psi 3 to 4 hours later it will drop 2 psi but i think that's normal .
    Great that you found your problem.
    There is a check valve in the fuel pump that is supposed to maintain some pressure after shutting the engine down. I don't know how long it is supposed to hold, but the 2 second "pump on" period when first turning the key to "on" is supposed to bring it up before going to "start". Sometimes mine will start quicker if I cycle the key to "on" for 2 seconds, then "off", then "on", then "start".
    Had you tried running a good fuel system cleaner through them? I've never had an injector problem (knock on wood) on any of my Accords; still running the originals in my 90.
    Leave a comment:
  • Accord problems
    replied
    Leave a comment:
  • Fleetw00d
    replied
    In the 1993 OEM Service Manual:
    Pressure with the engine idling and vacuum to the fuel pressure regulator removed and pinched: 40 - 47 psi
    Pressure with the engine idling and vacuum hose connected to the fuel pressure regulator: 30 - 38 psi.
    According to an old Haynes manual, the above values apply for 1991 - 1993
    For 1990: With vacuum hose disconnected: 35 - 41
    With vacuum hose connected: 35 - 37
    Leave a comment:
  • andrew22888
    replied
    It's around 32 to 42 psi. Also your link is bad
    Leave a comment:
  • Accord problems
    replied
    get it after asking on another site since no one knows . i will also put this in my sig for others to view . i got it from ericthecarguy.com .
    fuel psi for our accord .
    fixed it.
    Leave a comment:
  • Accord problems
    started a topic what is the fuel pressure
    what is the fuel pressure for the 1991 accord ?
    i've search this site and only found this .
    http://www.cb7tuner.com/vbb/showthre...t=fuel+presure
    i also looked in the manual but pages are missing.
