After replacing everything suggested, I still see oil drops. Here is my question
In this picture, I mentioned the valve cover gasket was replaced a couple of months ago. Inside the circle, should'nt you be able to see the gasket here? at least the rim of it?
Inside the square is where I can see the oil puddling up. If I put a tight folded sheet of paper towel in that cavity, there is no drop, oil stain, no spray, no mess, so I am 90% sure the oil is coming from there.
Also, there is NO oil in the spark plug cables nor in the spark plug holes.
If there were a damaged valve cover gasket, wouldn't there be oil in the spark plugs cavities/cables?
Is it common to have a faulty brandnew valve cover gasket?
