Hi All-
1992 Accord EX coupe with Nissin calipers. Just did the knuckle replacement with Acura rotors.
I continue to heat up REAL bad on front.
I changed pads out in Decemberand were evenly worn. I did the lube of pin thing, etc and replaced with Raybestos 496 pads(for Nissin Caliper). I had to work at it to get these into the caliper bracket. My caliper bracket has the stainless steel ends stuffed into the bracket where the pads glide on. I literally had to hammer em in. This is where my trouble started.
I was always running hot hubs/rotors and of course they warped. Pulled pads and inner was almost new, outer almost worn. Had a bear of time pulling pad from cradle.
Fast forward to yesterday and replaced rotors and pads with cheepie pads, 496 for Nissin. Inner pad dropped in nicely, Outer pad is VERY tight and is going to bind. Today coming home- I can't believe how hot these things are. did I mention they were HOT?
If I take a bench grinder to take a slight edge off where these slide along bracket- should I be okay? I can't figure out why this is happening- unless the brackets are different between Nissin and Akebono? Maybe owner before me put Akebono bracket on Nissin caliper?
WTF?
Thanks
Chris
WTF?
Thanks
Chris
