Swap a newer engine in. Seriously, there is no way to gain every single hp and lb-ft of torque form a 14 year old engine with high miles.
Agreed. but you can restore alot of hp for less than a swap, if your mechanicaly inclined that is.
Do a full engine rebuild and dont go cheap on autozone gaskets get oem its worth the money trust me. Also while your mucking around in the engine bay upgrade clean or swap your fuel lines/filter/pump helps with gas mileage and better fuel delivery. Check your axles/tranny for obvious wear and tear. Send out your radiator for a good cleaning or buy a taiwan/better equivelent, if the previous owner was dense he probably thought coolant lasted a lifetime and its probably mud by now. Also switching to Premium gas and synthetic oil allows your engine to run smoother than a babys behind
try some of these guaranteed gains w/o bust'n ur wallet:
-pull out your power steering pump
-pullout your a/c
-advance your timing
-set your vavles to the tighter specs
-synthetic oil's always good
-honda genuine MTF
-buy one of those universal filters and replace your airbox with it !!!
idk, i ran an engine flush and seafoam, change oil every 2500 miles. i have like no slush and can roast the tires liek no other...lol
<-just broke 220k miles
Just basic maintenance will bring your engine back to life and free up every potential stock hp. Fluid and filter changes, spark plugs, timing belt, valve adjustment, etc. Once you're all caught up in the maintenance dept. you can start adding aftermarket components to free up even more ponies.
Also while your mucking around in the engine bay upgrade clean or swap your fuel lines/filter/pump helps with gas mileage and better fuel delivery. Check your axles/tranny for obvious wear and tear. Also switching to Premium gas and synthetic oil allows your engine to run smoother than a babys behind
lazy fix= Seafoam
do all of the above.
also if u have the time try to clean the gas filter in the gas tank.
i would say seafoam.. but hey, maybe u isn`t better to just gain stock hp, DUH!!! get like a uintake and stuff.. seriously.. tell me this and ill tell u if u need to get another motor or stick with the one u have now tell me this..
mileage..
does it smoke
under what situations
how much oild do u burn
what color is the smoke
how much
what percent throttle when shifting does it smoke (mine smokes white right at redline, very small coolant leak)
just answer those and it will help us help u more...
lazy fix= Seafoam
dont forget to check the wheel bearings. sometimes they can cause a drag on ur car. also hopefully he didnt mean higher octane gives u more horsepower... it ALLOWS u to get more hp with the right mods. also some rubber seals arent really friendly to synthetic oils so u might get a leak. <-- SOME not all. synthetic oil has a high API rating and doesnt break down as fast as reg. oil. thats why it is so good. read about royal purple. they said if ur engine is "clean" and well kept u can keep the oil in there and jsut change the filter every 3000 miles.
-pullout your a/c
-honda genuine MTF
I would not follow his advice. I would however do what everybody else has been saying. Start with (always genuine Honda) spark plugs, distributor cap, rotor, air filter, fuel filter, OEM spark plug wires, new coolant, synthetic oil, Honda transmission fluid, an EGR port cleaning, a bottle of Honda's Top End engine cleaner and some fuel additive. That's sure to give u A LOT of performance back. Also, this is something that most people don't notice. Your accellorator pedal cable is most likely stretched after 12-14 years. It's always good to adjust it back to specs for that "touchy" feel the car had when it was new and to ensure that you can still get full-throttle as well. Mine had quite a bit of slack and it made a difference in the way the car felt. Also, make sure the tires are properly inflated (29 or 32 psi for 90-91 and 32psi for 92-93)
yes, pulling out your power steering pump and a/c will make some of a difference but will be a lot of inconvenience. Advancing your timing over the spec. degrees is not good for the engine. Adjusting the valves to "tighter specs" will most likely burn them up. Though i've heard that cold air intakes can make a difference in top-end, it will kill your low-end torque.. that's why the engineers designed the intake system the way they did.
mileage.. - 228 XXX
does it smoke - negative
under what situations - see above
how much oild do u burn - not really sure
what color is the smoke - clear lol
how much - what?
what percent throttle when shifting does it smoke (mine smokes white right at redline, very small coolant leak) nah men
btw i have an auto not manual
i gota change my cv boot cause every thing leaked out. my axel is almost done
cccheaaaa Accord Nation
92 accord sold, 91 accord ex-r still alive
240sx for that dorifto action comming soon
yup
the reason why i made this thread was to maybe get some one say this
on my bday im racing my friend with a 87 camry vs my 91 accord
my cable is loose and legacy accord is going to help me with the cable problem aparently
Good advice xaxis360. I read that but I did not want to flame the thread. IMO, restoring an old engine back to stock preformance specs is a really tough endeavor. Personally I feel that a swap would be cheaper than an overhauled 150k mile engine.
the thing is that if the engine doesn't burn any oil and u keep up with the maintencace then it should have all the hp that it had in the begining.
tranny well that is a different story
