i hear people say, oem is the best... but im considering getting a greddy belt. has anyone heard good or bad things about the greddy belt? i need one asap, i snapped mine today
Best Timing Belt?
Prob they use different materials inside the belts so they are stronger. Id say go for it GReddy is a reputable company.
Originally posted by TypeGyour probably going to need more than just a new belt. later.
and about getting a greddy belt, im not doing just for the hell of it. i NEED a belt, im just considering a greddy instead of an oem. and with the way i drive, to 8k daily, it couldnt hurt to have a stronger belt, assuming they are. im not sure if it was a freak incident or what, ive been on that belt for about 40k, sooner than expected, but until its taken apart at the shop i wont know if there was some sort of foulplay.
are greddy belts supposed to be stronger? i wouldnt be suprised if youre paying more for the name, but i figured it couldnt hurt to ask.
Greddy, Toda and all of them make there belts out of some sort of different material supposedly so they are stronger than OEM belts. Thats what i have heard. It wouldnt hurt giving a try. Damn broke 2 auto tensioners already thats crazy. You upgrade to a manual tensioner?
Originally posted by DrLove'sKuDangwell im keeping my fingers crossed. and thank god for good h-series clearance. ive broken two auto tensioners and ive yet to bend a valve. anythings possible, but im hoping for the best. i was just cruising when it happend, and my car just suddenly died, so i coasted to the side of the road. i didnt hear any funny or "bad" noises, so i guess i see soon enough.
This basically bumps your belt change interval up to every 60,000 miles instead of every 90-105K depending on the year of your engine. It isn't a bad idea to change the water pump either obviously. With the exception of the auto tensioners, you probably wouldn't have a problem if you changed them more frequently as recommended.
Unfortunately, I have the same problem. I have never had a belt snap early, but I have had a water pump fail. I voluntarily moved it up at that point to avoid future issues.
well i went with oem afterall. not by choice but convience. i had the car towed to the shop after work today and i was planning on leaving it there for a couple days till they worked through some cars they had lined up already. but they told me to pick a belt up from honda and they would get it out today, so thats what i did... pays to know the owners
and it runs fine. so ill hopefully be getting retuned this coming weekend. they have a plan to take a couple cars to dyno at tech3... i want to tag along if im not working.
Thats good to hear your car is back up and running. Lucky that you dont have any wierd sounds coming out of it. Have you done the manual tensioner conversion yet on your car since you said you already broke 2 auto tensioners?
Originally posted by NAiL05Thats good to hear your car is back up and running. Lucky that you dont have any wierd sounds coming out of it. Have you done the manual tensioner conversion yet on your car since you said you already broke 2 auto tensioners?
