spark plug wire popping off
    recently, one of my spark plug wires has been popping off the engine cover. what could be causing this, and would i be better off getting a new set?
    edit:: i spelt plug wrong in the title lol, my bad, fixed
    is there resistance when you put the plug ont he spark plug?
    I <3 G60.
      my friend had this happen to him.. it jacked his plug wires up. maybe thats the case.
      always out numbered never out gunned..
        nope, the plug cap just pops back on
          Could be faulty tube seal, or a loose plug. Either way it's possible the compression is popping it off, or the crankcase pressure is. Is your PCV valve operating properly....
          1992 Accord LX - SOLD
            are the spark plug wires the correct ones for your model year? only reason im asking is i see alot of wire sets that say for accord 90-97, and i dont think they fit sometimes. when i put the f22b1 head on my car and tried to reuse my f22a6 wires i had the same problem. i know its a remote possibility.
            good luck tomd
              Change them asap.
              The boot area of the spark plug wire is faulty, worn most likely.
              Replace your wires with NGK blue wires, they are at least made in Japan and are decent in price. ebay` it.
              You can get the Bosch ones, which aren't half as bad, but just get replacements soon.
              My Accord did that. Cylinder 3 wire kept poppin off and the idle was erratic all of a sudden...you could cause misfire if one cylinder isn't being sparked(fired) correctly.
              1990 Accord Lx F22a1(Daily) SOLD - will be missed
              1990 Prelude Si B21a1 (Fun car!)
                Originally posted by Accord13&BA4
                Change them asap.
                yea i was thinking of just buying NGK's. cylinder 3 is also the one popping off, but i haven't encountered and erratic idling or misfiring yet. hopefully everything is fine until i get new NGK's. is there a product number i should be looking for?
                  Yeah the same thing was happening to me my plug was loose hasn't poord off again since I tightened it but could also be bad wires get how much do the ngks go for?
                  Ride List
                  1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
                  2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
                  newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
                    i see some blue NGKs on ebay going for around $50-60 shipped. i'm not sure if these are the right ones though
                      Don't replace your wires yet, check to see if compression pressure is leaking past the threads on your spark plugs, since it's one plug wire and it is still popping off, it's probably a loose plug.
                      -Kyle
                      SOHC Non-VTEC F-series for life
                      "It is the fools prerogative to utter truths that no one else will speak."
                      -Morpheus (The Sandman)
                        -Kyle
                        how do i go about checking the pressure?
                          I had a set for sale, NGK blue wires for a good price. sold, always when you need that shit
                          Yes, they range from $50-60 dollars...depending on your year, you may have to get the one with the coil wire as well, but check your motor, see if it needs one.
                          I agree with Wiccanvampier...
                          If cylinder 3, the sparkplug wire snugs back on, have you checked your spark plug itself?
                          Most likely, the insulation on the spark plug wire does not fit anymore, or has worn out...tell me this...
                          are you wires stock? meaning, black spark plugs wires? if so, wipe off the crust and oil, and examine the wire...it will have a "born on date." 1990, 1991...in red, small ass letters too...
                          It's always good to upgrade wires, better conductivity, flow. There are no needs for the 8mm, huge magencor wires, unless used for another application.
                            i think i am going to just get a new set of NGK plugs. does anyone know if
                            http://www.ngksparkplugs.com/
                            or
                            http://www.ngk.com/
                            have warranties on their parts?
                              NGK, NGK, NGK: Primary supplier to Honda of spark plugs
                              Bosch = poor fit
