i lost my key set and can`t use it because i went to get another one from honda and my igniton has been rekeyed.. so anyways.. i am hooking up a toggle switch and push button for the time being.. i looked at the back of the igniton and the wires say battery, accessory , accessory 2, and starter.. so i would imagine i would run battery to one side of a toggle.. 1 and 2 to the other and draw power to a push button and put the starter wire on the other end.. right?? anyone had experience with this...
key ignition wiring help...
here.
take apart ur ignition column.
take out the 2 screws that hold that white thing in place, the whole piece would come out...(ignition switch)
turn that little dial with a key or some screwdriver, there congrats u just jacked ur car and now can start it...make sure the metal doesnt touch anything else.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
