Good day everyone.
I tried searching for DRL setups, but nothing really firm came back. What options exist to adding OEM style DRL's to a 91 US Spec Accord? Is it possible to obtain the correct DRL module (Mitsuba RZ-0126?), add the fuse, and be good (plug and play if you will)? Or do I need to find some other way?
If I need to find another way, can someone point me in the right direction or provide some recommendations to DRL kits and/or modules?
Looking to simply use the high beams as DRLs, but they shut off when the parking lights are on OR the e-brake is pulled up. Once DRL system is deactivated, then normal headlight operation resumes.
Thanks!
Thanks!
