I ran out of grease that is supplied with the clutch kit. I got some high temp from autozone. Will that work?
What is a good grease substitute for tranny spline
Yes that will work. Very little grease is supplied with the kit because it takes very little grease to lube the splines on the input shaft. Put too much and centrifugal forces will sling the grease onto the friction disc causing slippage. I put a little on the splines that the friction disc rides on, a thin film on the inside of the throwout bearing sleeve,and a dab on the clutch release arm where it contacts the bearing.
