Well. Open for suggestions....
Passenger side hi-beam does not work
- Use to work just fine
- Getting no volts on wire
- Bulb /headlamp works if voltage supplied
- Getting 12V on fuse #37 at fuse box but not 12V to wire coming out of fuse box
- Resistance of wire to fuse box is good
- Tried swapping headlight relay and dimmer relay for spares
- Tried swapping the fuse box, same
- High beam indicator works in dash
- Heck... everything else on the car works. Every light, switch etc.
Confused about the "ground" side of this connection. In the manual it just says it goes to the dimmer relay in the fuse box. But when you trace the wire it appears to go to the ECU. The other ground it mentions obviously works as its the same ground for the rad fan, etc.
I feel like I'm missing something here. Both headlights share the same relay for headlamp and dimmer. What's stopping the fuse box from outputting the 12V. Not sure what else to try here....
