So am thinking of replacing my cylinder head and i got a f22a6 engine. Is the f22a6 engine cylinder head the same as f22a1 and a4? The guys who stole my car revved my engine and sprang a leak possibly in my head gasket. No oil is leaking into water or vice versa but oil is leaking out it seems from cylinder head on drivers side engine near that drivers side motor mount. So I think I got to pull head off and replace head gasket. So why not just replace the cylinder head I thought. My main question is all those cylinder heads the same. I see reman pt3 heads. Is that what I need?
Is f22a6 cylinder head same as others?
the casting itself is the same. however the valve springs, cam and tune are different. but since you said the water and oil aren't mixing, then maybe you want to look at some different seals like the crank seal, cam seal,oil pan gasket, ect. before doing such major work as a head gasket. maybe perform a leakdown test first. later.
Originally posted by TypeG View Postthe casting itself is the same. however the valve springs, cam and tune are different. but since you said the water and oil aren't mixing, then maybe you want to look at some different seals like the crank seal, cam seal,oil pan gasket, ect. before doing such major work as a head gasket. maybe perform a leakdown test first. later.
