What pin on under dash fuse box is left and right turn signal
  • Raf99
    replied
    Sorry i didn't read your other fuse box thread, seen enough people on it. But you mean which wire and not pin. The wire is GRN/BLU wire and it goes to drivers fuse box as the same colour. & then it gets complicated as it goes into the "ICU" that's on the fuse box. That pig of a box that's impossible to remove. I had to replace mine.... but what was the issue........ (5min later)... Oh ya.. was to add the delayed wiper switch. So now I have one of these spare brown boxes that are part of the fuse box which controls marker lights, wipers, etc. & there's no one fuse for your signal lights. You're chasing a ghost.... replace the fuse box
    Leave a comment:
  • What pin on under dash fuse box is left and right turn signal
    Does anyone have a diagram on what pin and connection the right and left rear blinkers are one coming from the turn switch on steering wheel. Am assuming the turn signal from hazards run off a different pin. I have fuse box issues and i need to track down which is which.
