replacing CV axles
    replacing CV axles
    I'm probably gonna be doing my CV axles myself now... wondering, what would be the best thing to do with the knuckle? Should I pop out the tie rod end or the lower ball joint to let it move to allow removal of the axle...
    Thanks
    George
    also what size socket should I buy for the axle nut? I have taken this kind of stuff apart before I just dunno what size this one is
      Leave the tie rod as it is, remove the damper fork, and break the ball joint loose from the lower control arm. the nut is 36mm.
      My H22A SWAP JOURNAL
      Members Ride
        thanks bro!!! To remove that nut, i will probably HAVE to use a socket, right?
          ^Yeah, a 1/2 dr. 36mm socket. And if you haven't done this already, just pop the tie rod end out too, so you can swing the knuckle out enough past the end of the axle.
            well the pass. side axle was still good, driver's side was HORRIBLE. they are done now, all it took was poppin the ball joints out.
            Thanks guys!
