replacing CV axles
  • monkeydude3
    replied
    well the pass. side axle was still good, driver's side was HORRIBLE. they are done now, all it took was poppin the ball joints out.
    Thanks guys!
    Leave a comment:
  • Granite CB7
    replied
    ^Yeah, a 1/2 dr. 36mm socket. And if you haven't done this already, just pop the tie rod end out too, so you can swing the knuckle out enough past the end of the axle.
    Leave a comment:
  • monkeydude3
    replied
    thanks bro!!! To remove that nut, i will probably HAVE to use a socket, right?
    Leave a comment:
  • TysCb7
    replied
    Leave the tie rod as it is, remove the damper fork, and break the ball joint loose from the lower control arm. the nut is 36mm.
    Leave a comment:
  • monkeydude3
    replied
    also what size socket should I buy for the axle nut? I have taken this kind of stuff apart before I just dunno what size this one is
    Leave a comment:
  • monkeydude3
    started a topic replacing CV axles
    replacing CV axles
    I'm probably gonna be doing my CV axles myself now... wondering, what would be the best thing to do with the knuckle? Should I pop out the tie rod end or the lower ball joint to let it move to allow removal of the axle...
    Thanks
    George
