Alright, so I took my jdm f22b camshafts out, replaced the timing belt, cleaned everything up, replaced some seals, now I'm trying to put these mofos back in. Having some trouble, because when I try to line the cams up with TDC, the lobes are putting pressure on the rocker arms and not lining up all the way. Any suggestions on how to reassemble the valvetrain? I'm gonna try putting the timing belt on without the journals, then putting the journals on last.
h23/f22b valvetrain ???
the should be two little holes on the two last cam caps closest to the cam gears. and there's also two matching holes on the camshafts themselves, when lined up at TDC, those two should line up and you can hold 'em even with an allen wrench, lil screwdriver or w/e you prefer
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
