i was reading that u could bypass the dampener on the cluth lines i was wondering what kind of effect this may have on the clutch i am doing a 5 speed swap and i would be easier to just bypass this and put a ss line in from the cylander to the slave here is the link http://accordinglydone.com/forum/sho...ht=5speed+swap
clutch dampener
clutch dampener
member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973Tags: None
so thats where the line goes.......
i've never put a manual car together and couldnt figure out what line goes to the slave and also that pipe that does a weird "S" then goes into a rubber line, then where that goes???"You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
um yeah but have u bypassed the dampenser before
its the thing that has the hardline going into it and has a rubber line connecting two cylander things together then goes to the slave
bump
what do u mean comfort like will the cluch be harder to push down or something
I tried to rip the damper out of my parts prelude to swap into my good prelude when I did the 5 speed swap. It was rusted in so I made my own lines. Comparing my clutch pedal with my custom lines (SS flex from MC to slave) to a factory 5 speed car, there is little to no difference in pedal feel, effort, or response.
In short, you don't need one.
nice thanx have you had any problems since, i heard later down the line some had problems with it
well im doing a manual swap and want the easiest way of doing it so if i can bypass it then thats what i will do i was basicly saying could i cause any damage or be bad at all for my car
