Hey hey everybody~
I saw this idea on this site and a few others but the DIY was a little lacking and didn't have as many pictures as I like.
PURPOSE: 9005 bulbs have 30% higher lumen rating than 9006. Using brighter bulbs means you can use cheaper halogen bulbs and get better brightness than the expensive Silverstars (last ~2yrs) and the other hotter bulbs.
WHAT YOU NEED:
1) pair of 9005 high beam bulbs (I used Silv Xtravision)
2) Dremel with a fine tip cutting bit- like this kind
THAT'S IT!
STEPS:
-just a friendly warning: *DON'T FREAKIN' TOUCH THE GLASS ON THE BULB* the oil from your greasy little nubs will burn 'em out in a hurry!
1) Take out the old 9006 bulbs. It can be a pain to get the ring clip off if it's seized but it's doable.
2) On the 9005, dremel off about half of the top tab STARTING FROM THE LEFT.
You can hold up the 9006 to see where the tab will need to end.
3) Inside the plug, the 9005 will have 2 guides and the 9006 will have just 1 in the center. Therefore, they need to go. Dremel away with a steady hand but don't worry much about damaging the contacts.
9005 (trimmed)
9006 (still with guide)
4) Clean off all the plastic shavings and put your new bulbs in.
5) Opt. adjust your headlight aim if necessary.
It really is that easy!
RESULTS:
Left= Mod Xtravision; Right= 9006 Silverstar
Left= 9006 Silverstar; Right= Mod Xtravision
-Keep in mind that this is in the rain on a Samsung Impression. No macro, no zoom, no glare control.
-The Silverstar's are whiter but the Mod Xtravisions actually shine brighter in the short distance and go a little further (pic 1 really shows it best).
-If I get a chance, I'll try to shine em on a flat wall but the coverage is great with the mod and they don't shoot too far up and glare people.
GOOD LUCK!
Shankenstein
WHAT YOU NEED:
THAT'S IT!
STEPS:
9005 (trimmed)
RESULTS:
GOOD LUCK!
Shankenstein
