INT : Check Engine Light switch
    I was really bored today, so I decided to install a switch on the Service Check Connector (CEL plug). First of all, I did not come up with this idea myself. I was "inspired" by cp[mike] in a post about reading CEL codes, but I thought I would do it a little bit different.
    I wouldn't exactly label this DIY as a must do, but since I am periodically getting codes and performing maintenance which requires the circuit to be shorted, I decided that this would be a convenient addition to the car.
    Parts List:
    -------Necessary Parts----------
    1 x Male 2-pin connector (Radio Shack #274-154, $1.99)
    1 x Female 2-pin connector (Radio Shack #274-151, $1.99)
    1 x On/Off switch (Radio Shack #275-730, $2.99)
    2 x 1/4" Female quick disconnects (Radio Shack# 64-3133, $1.69)
    1 x 6" piece of ~14 gauge dual strand wire (speaker wire will work fine)
    --------Optional Parts----------------
    (1) x 3x5 photo paper
    (1) x Piece of laminating paper
    Tools list:
    Fine point Sharpie
    Dremmel
    Dremmel cutting wheel
    Dremmel soft metal cutting bit (looks like a wood router bit, but made for metal)
    Dremmel diamond embedded grinding bit
    Wire cutters
    Wire crimpers
    Procedure:
    Step 1. Remove the kick plate that covers the SCC (Service Check Connector or CEL Plug, whatever you call it).
    Step 2. Using the mounting bracket supplied with the switch (#275-730), trace the inside of the hole onto the car frame using a fine point Sharpie. Center the hole as close as you can.
    Note: On the bracket, there is a decorative "lip" around the top edge. I ground this down so that the bracket would sit flush against the frame for better tracing.
    Cut out the traced hole, and don't forget to cut a notch (look at the switch!)
    Step 3. Remove the black hole cap located just below the new hole. Cut a small hole in the cap to allow the wire to pass through.
    Step 4. Cut off the existing blue SCC, and install the female 2-pin connector (#274-151) in its place.
    Step 5. Assemble the connecting wire by attaching the male 2-pin connector (#274-154) to one end. Pass the wire through the black hole cap. The male 2-pin connector should be exiting out from the cap when installed. (In other words, when the black cap is reinstalled, the 2-pin connector should be sticking out, and the two quick disconnects should be inside the frame). Then attach 2 female quick disconnects(#64-3133) to the other end of the wire.
    Step 6. (Optional) Install SCC label on frame.
    Step 7. Pass connecting wire in from the lower existing factory hole up to and out of the newly cut hole. Ensure that the black cap is properly installed as it was before removal.
    Step 8. Ensure the hole is cut to the correct size. Connect the switch to the 2 quick disconnects and install switch into the newly cut hole.
    Step 9. Connect the male and female 2-pin connectors.
    The kick plate reinstalls perfectly without any interference. Now you can read codes or make adjustments with the flip of a switch!
    The final result came out really well with the exception of the switch being slight tilted. I guess I was a little of when I notched the hole. Oh well, at least it works!
    Tips on the label: I created the label using MS Word. I printed it on Photo paper to give it "real" look. Before cutting it out, I covered it with laminating paper to protect it (just in case). I cut a hole (using the bracket as a template again) and stuck to the frame using Elmers Glue!
    If anyone wants the label, it is attached below.
    Let me know what you guys think.
    damn thats badass I'm gonna do that. good work man!
    always out numbered never out gunned..
      i been thinking about doing that latley. hehehe i went cheaper, i made a jumper to just plug in to it lol...its not a bad idea though...just make sure that you dont flip it by accident.
      Retro!
      Hater
        nice looks good if i get a cel ill do this for the fuck of it ya know
        Ride List
        1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
        2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
        newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
          You know, I've never jumped that service connector. I always just pull back the carpet and look at the ECU.
          -Jay
            yea thats another way to do it. but I still like the idea of just flipping a switch and avoid having to spend the extra 30 secs pulling the carpet back
              Love this idea I'll be doing it today since I pulled off all my interior panels to have them painted, I'll have fun doing this while I wait for them...thanks for the DIY...:tu:
              God First, Family Second, and CB's for fun Third...
                this is super bad ass i think that im gonna do this , but i might mount the swith inside the glove box so that it doesnt accidentally get switched if someone kicks the panel. also that photo paper label is sick , good DIY
