EXT: Wiring JDM Headlights
Originally posted by JDMHondaGuyDose it matter witch wire goes in where in the sockets?... I wasen't sure if it mattered or not.
Btw, Great DIY!
Leave a comment:
[QUOTE=jsinger]As far as I know, no it doesn't matter. That or I just got lucky the first try on all four plugs. If you discover otherwise, just switch the terminals.
ok thanks, i'll try it!
Leave a comment:
is there a need to re-aim the direction of the headlights? if so how do you do it?
Leave a comment:
Btw, Great DIY!
Originally posted by AlmightyAccordgreat DIY for ur first one
Leave a comment:
Btw, Great DIY!
Leave a comment:
Originally posted by hondaracer33Thank-you
I used this from beginning to end.
It was perfect.
Leave a comment:
I once went jdm but looks nice but saw no point in it then converted back for one the bulbs where expensive,hard to reach the corner bulbs and such then i went back but great writeup though i give you that
Leave a comment:
I'd say you did pretty good for your first DIY. Great pictures too!
Leave a comment:
Originally posted by owequititGreat write up!
I have wanted to do this, but wasn't sure where to get the male sockets! You saved my behind.
It wouldn't be a bad idea to solder those pins as well. Then they would be that much more secure, but I doubt that it will prove to be an issue.
Originally posted by cp[mike]exactly how i did mine, thanks for taking the pictures and posting up a guide, now i can refer people to it when they ask about it.
perfect write up! the ONLY difference that i would suggest is in the picture below - instead of cutting the pins along the green lines like you said, id recommend cutting them at the red line. that way that extra bit of bare connection isnt left hanging out of the back of the connector... but then again, you can leave it and use it as extra support holding onto the wire insulation, but make sure its taped up well like you have in the pictures.
Thanks for the positive feedback guys!
Leave a comment:
Leave a comment:
Great write up!
Leave a comment:
Leave a comment:
