I finally got around to installing my CB6 Sidemarkers and I took lots of pictures in hopes of finally making a DIY for this, since there doesn't seem to be an official one. Most of my research for this project was found here on CB7T. There are atleast 25 pictures @ 640x480 res for this DIY, so 56k proceed at your own risk!
Complete JDM Sidemarker Install
Disclaimer: I am not responsible if you injure yourself, others,
or the parts you are working on. Proceed at your own risk.
** What this DIY will cover **
This DIY is broken down into two parts. Part I will cover the cutting of the fender for the sidemarker. Part II will include wiring the sidemarkers and the final installation.
** Please Note **
Understand this is meant to be a general guide for a sidemarker installation. There are many types of sidemarkers with different shapes and bulbs and so forth. In this DIY I used sidemarkers from a CB6 Accord in Japan. Your actual sidemarker template may differ from the one I made.
Now lets get started.
Part I: Cutting a hole for your sidemarkers
Parts, Tools, and Safety Equipment used:
* Writing Utensil (pen or sharpie)
* Sissors/Razor Blade
* Ruler
* Card Board/Side of a plastic milk carton
* Dremel
* Dremel Heavy Duty Cut-off Wheels #420
* Stoch Blue Painters Tape
* Touch-up Paint
* Eye Protection
0001
Using a pen and a ruler, I started measureing and making templates. I think I ended up making four templates before I got a template that was usable. I took a empty poptart box and unfolded it and used it to make my drawings on. I then used a razor blade to cut out the template. I test fitted the sidemarker into the cardboard template to make sure it fit nice and snug.
Proceed to the next post...
** Please Note **
* Ruler
* Dremel
* Touch-up Paint
* Eye Protection
0001
