I'm getting ready to do this too. this thread inspired me so i went to PnP and grabbed some. In my tails there are some side facing running lights that I'm going to tap into. So that way I don't have to go all the way across the trunk from the right side light.
had to do that too otherwise the light was stickin out. As for the wiring... where did you connected both wires? I tapped mine to the tails but when i hit the brake they go off and when i release it comes back on...
i used the tow harness located about the drivers side tail light. mine come on with the parking lights and stay on steady until the lights are turned off.
There is an air trap, I had to grind mime down with my dremel.
Leave a comment:
