1 take a thin piece of metal about 6 tp 7 in long and 1/2 wide the at on end thinn out the width just a little sorry i dont have just finishing product then at the other end drill a hole enough to get a 10mm bolt threw then on the other end where u thinned it out so the piece will be flat bend it to the leftthere should be aleast an inch that has been bent
2 loosen the hose clamp from the filter and tuck the metal piece throughthen bend end so basicly u want like a horse shoe shape then tighten the clamp up and bolt the other end down should look something like this
