ENG: How to test Low Fuel Light bulb
    Okay, like many of you on here, I didn't know if my recently purchased CB7's low fuel light worked or not, so I tried driving it to as low as I could tolerate and the light didn't come on. Now what? Well read on.
    If you are unsure whether or not your bulb works, you can do this:
    This is going off instructions from the HONDA factory manual that I have:
    1. Locate the Fuel Sending Unit in the back of the car. Its right beneath the rear seat, fold down the back seat and lift up the carpeting and you'll see it towards the right side of the car.
    2. Remove the three phillips heads screws to uncover the access cover.
    3. Unplug the 3 Pin connector from the Sending unit after removing the rubber connector cover.
    4. Now, take a jumper wire, any small gauge wire will do and jump terminals A (Green/Red) and C (Black) of the connector you unplugged.
    5. Stick your key in the ignition and see if the low fuel light comes on. If it does, then your bulb isn't burnt out. Don't be alarmed that the fuel gauge will go down, since you did unplug the connector.
    The low fuel light only comes on when there is less than 2.2 gallons left in the tank. Our tanks hold 17.1 gallons, so you would have to of used over 14.9 gallons before it should come on according to the factory manual.
    Hope that helps you guys determine if your light bulb works or not.
    Oh, and the manual said if the bulb doesn't come on, and you have in fact driven more than 14.9 gallons, then its most likely a faulty Sending Unit causing the low fuel warning to not come on.
    member's ride thread
    91 Accord SE 176k
    Nice! I found this very useful. Thanks for the info!
    Form.Follows.Function
      Something I'm def going to test. I don't ever remember the Low gas light coming on , and the needle has last the E more than once lol.
      Nice find/post DIY
      Check Out My Work In Progess . . . . .
        Mine works but its strange
        it will fade in and out.
        i want to buy a brand new fuel sending unit.
          Mine too. Maybe its normal...
            I don't think it is
            If i bought a car brand new and it did that i sure wouldn't be happy
            The low fuel light does not use the float
            It has its own little piece separate from the float
            heres a DIY so you can see what it looks like
            http://honda-tech.com/showthread.php...6#post45005986
              I know mine doesn't work..whenever I'm not lazy I'll try this out.
                My low fuel light also fades first it turns on then it fades away. I drive a little bit Then it does it again. Then finally when its past the E it stays lit. Maybe when it fades in and out it means "Dude get gas" Then when it stays lit it means "You're screwed"
                http://www.cb7tuner.com/vbb/showpost...53&postcount=4
                  sweet DIY bro great info
                  lmmfao i think this tooo
                    Both my CB's Fuel lights faded. Its probably normal
                    -Will
                      Mine does the same thing. But I think because the fuel messes with the float everytime you accel and deccel.
                      Henry R
                      Koni/Neuspeed
                      1992 Accord LX R.I.P
                      1993 Accord EX OG since 'o3
                      Legend FSM
                        well you also gotta remember that the fuel sloshes around in there when you're driving so its hard for the float to get an accurate reading when this is happening. So, until the fuel level is low enough for the sensor to trigger the low fuel light, it'll probably fade in/out
                        91 Accord SE 176k
                          ahhh well I found out that I think my sending unit part is bad. Even though the light works, i drove until I had filled in 14.9 gallons and still no light.
                          So it must be the arm inside the tank, attached to the sending unit that is malfunctioning.
                          91 Accord SE 176k
                            No
                            the low fuel light does not use the arm. That would be pointless because then you would have two things side by side displaying the same information.
                            The low fuel light uses an extra sensor like i said in post 6
                              No
                              is the sensor replaceable? Or serviceable?
                              91 Accord SE 176k
