Fixing Window Pin Kit
Do your windows rattle when they are rolled down, and make a nasty sound when you shut the door? If so, and you have a coupe, the culprit may very well be the window pin kit/guide at the rear of the window. They will rattle for quite some time until the guide will fall off, then you have no choice but to replace it.
I think this problem is mainly only an issue on coupes since the doors are larger, and there is more glass to keep aligned for 15 years. If your sedan is rattling, most likely you just need to take the door panel off, and tighten up something.
Parts
*Phillips and flathead screwdriver
*10mm socket
*t-10 or t-15 star type bit or 5/32 drill bit (easiest)
*New pin kit Honda Automotive Parts - It is item #1, product 95731. To buy it locally just print off that page, or just remember "window pin kit"
Down and dirty
1. Roll down the window leaving about 1-2 inches showing. Then remove the door panel. There are 3 covers that you need to pop off, and two in the door handle. Here is a thread that shows how to remove the panel. For power windows, all you have to do is disconnect the wires from the back.
2. To remove the door handle, you unscrew 2 phillips screws, then you must take a flathead screwdriver, and undo the linkage at the rear of the handle. You'll understand when you see it.
2a. To make it easy to adjust the window, and make sure it works. Take the window switch out of the door panel (one screw under it, and just pry it out) Do this after the door panel is off and it'll be easy.
3. At the rear of the window, there is a cover that you can peel off, which will reveal 4 screws. Peel it off, and unscrew it.
4. You can now pop that black track out (dont pull the black rubber molding at the front, its not attached to the track. (track is pictured at the top of the picture. The little cover piece is at the bottom)
5. Now go to the bottom of the door, and loosen the 2 10mm bolts about 2 turns. 2 bolts are circled, if you cant see the front one, roll up/down the window until you can.
6. Pull the window out of the top of the door. Pull the rear out first and it should come out smoothly. Lay it on a towel so it doesnt get scratched.
7. You now need to take the old window pin off. Either use a bit that will fit it (remember to turn right to loosen since you are unscrewing the part on the other side). I used a 5/32 drill bit, just drilled it out and popped it off.
8. Put the new one on just like the old one. You dont have to overtighten it, just get it nice and snug so it doesnt wiggle around.
9. Look in the bottom of the door for a rubber molding that looks like this. It belongs in the bottom part of the track at the rear of the door. I put the cut part at the top, and the small lip towards the inside of the car, and didnt re-use the plastic clip that goes at the bottom.
10. Turn the pin kit so the guide part is closest to the rear of the window, and drop it back in the tracks. Then put the two 10mm bolts at the bottom of the glass in the regulator but dont tighten them down yet.
11. Now slide the track back into the rear of the door, making sure the window pin goes in the track. Line up the screw holes and tighten them down
12. Put on the cover strip. Mine didnt want to stick so I used some non-hardening black gasket sealant in a few spots.
13. You can now tighten up the 2 bolts at the bottom of the glass.
14. Test the window, if its running a little slow, spray silicon lube down the front and rear tracks.
15. Reassemble the door panel and clean your window from all the grease.
i was 2 lazy 2 do all of that cuz i wanted to be able to roll down my window again cuz i had to work like an hr l8er. Im only 17 so yeah im not motivated
