materials
-plastic polish
-cotton cloth
-sandpaper (400g 600g 1000g 2000g)
plastic polishing
custom int door handles
here is an ordinary hazard switch (thanks Tommi).
start by removing the frount of the button. you can pry it off carefuly from the front or the back like this:
once off, start sanding the paint off the button with 400g. it will look like this:
when you are done sanding the paint off, go to a finer grit paper like 600g and work your way to 1000g and 2000g. after that, use the plastic polish. it'll look like this when done:
if you work at it for a while you can get rid of the red dust inside the button.
here is what it looks like done:
here is what it looks like on in the car:
if you feel the need to do this, you can also do the cruise contol &, sunroof buttons, a/c buttons, defrost button, hazard button, ect. however, i don't think anyone will ever do this, it was more for fun. later.
-plastic polish
-cotton cloth
plastic polishing
